App for Accessing Office 365 Sharepoint
Stephen86
Hi All
We had been using SharePlus for Office 365 but now that I'm deploying it through the VPP they want $27 per user per year. Would be happy to pay it as a once off but not as a subscription.
So dose anyone know a good app for working with Office 365 SharePoint that is free or has a once off purchase. It needs to allow you to use the open in function and copy to function. As we use send to feature to take files into Docs To Go to edit and the Copy to (AppName) feature to upload them back into the portal.
I'm stuck with old iPad 2 units and iOS 9.3.5 so would need to be compatible with that.
2 Replies 2
SteveWorks
Just browsing
Stephen,
If you still consider other office option, Polaris Office/SDK could be an option. 🙂
MikeMandalorian
To clarify    Microsoft wants 27 PY for each user not VPP correct?    reason why i asked, on my VPP it says free.  Sharepoint app is for IOS 7 + so should be good with your devices . alternative would be  Polaris or OpenOffice
