Android Contacts Sync
I'm trying to get outlook to sync its contacts with the default contacts on a Samsung android device, I have set the app permissions to allow the sync but keep getting an error saying access is not fully granted
Please can someone provide some assistance
6 REPLIES 6
Re: Android Contacts Sync
@danielpage  what have you get set in your System manager profile settings?
@BlakeRichardson
These are the setting within the managed app config setting
What happens when you remove the 2nd key?
Just thinking that could potentially be the issue
Nothing, still has the permissions issue shown in the first post
Are you seeing this on multiple devices or just this one device? What specific hardware and Android OS version are you using?
You need to add app permissions with :
it's working for me !!
