Android AppConf setting of type BundleArray not working
LeifA
Trying to maintain settings for a specific Android app (Mobisys MSB App). One of the parameters is of type "BundleArray", as shown below:
But when trying to add this parameter, there is no way to enter any data into this parameter, the field "Type" is blank and no input field appears:
Is this a bug in Meraki? This is supposedly working on other MDM tools, as we have been told by the app supplier.
Any input appreciated!
Leif
2 Replies 2
BrechtSchamp
That does look like a bug or rather limitation in the GUI. I think it's probably best to open a support case for that to see if this is a known limitation.
I too have a few apps that do not show bundled settings.  I think they basically need to add support for OEMConfig.  I was going to put in a feature request for it today since I didn't see much out there on it.
Not many EMM's have this enabled for Android at this moment.  Actually, they don't have it for iOS either, but I suspect the apps published this past month will provide the impetus for them to get the api's loaded soon.
