A connection to the server could not be established. [MCInstallationErrorDomain – 0xFA1 (4001)]
trunolimit
I'm trying to supervise some iOS devices but this error keeps popping up. What gives?
MerakiDave
Open a case with Meraki Support, I believe there is a known issue regarding an invalid response from the SCEP server and the SM team is working on it.
trunolimit
Well that's annoying. OK just opened a case. will report back if a solution is found. seems like a few people have had this issue before but no solution I've found.
i had that when ( using AC ) trying to supervise an iPad which was already in someone's else DEP
