What API can be use for Usage Monitoring
Farrukh
Is their is an API that can be use for the up link Usage Monitoring of an AP?
3 REPLIES 3
CptnCrnch
Could you please elaborate what "usage" means to you in this regard?
Total bandwidth usage per network or per device  and uplink Usage
sungod
For a network there's...
https://developer.cisco.com/meraki/api-v1/#!get-network-traffic
But I recommend read through the API documentation and get a feel for what is available, then you can decide which endpoint(s) will best fit your need.
If you want a device level view, the endpoint(s) you need to use will depend on the device(s).
