Return switchports matching a specific tag in v1?
ChrisLaird
I'm trying to monitor a specific set of switchports across our network. All of them have the same tag (cameras), but are spread across ~300 switches and ~10,000 switchports. Of those 10,000 ports, I'm only interested in the 85 that match the tag.
In the old v0 API, I'm finding plenty of examples that would have worked, and ChatGPT is happy to write me a script that should have solved my problem in about 5 seconds. But it seems that, in the new v1 API, I can only query ports by switch, not by tag, so I'll need to return every switch, then every port, then filter out just the ports I need. Then, querying those ports to get their usage within a time period seems like an additional layer of issues in v1.
Is there some mechanism to do this that I should be seeing? If it used to be as simple as "https://api.meraki.com/api/v0/networks/{network_id}/switchPorts/usage?timespan={six_hours_ago_unix}-...}", I'm hoping that they gave us a new method when they took the old method away.
2 REPLIES 2
David_Jirku
How about the org-wide switch port API call
https://developer.cisco.com/meraki/api-v1/#!get-organization-switch-ports-by-switch
and filter the results by tag, which is returned?
rhbirkelund
I haven't tested this in action, but something I suppose it's something along the lines of this. Feel free to use it as inspiration.
#! /usr/bin/env python3
import meraki
from datetime import datetime
def main():
    dashboard = meraki.DashboardAPI()
    organization_id = ''
    TargetTag = ''
    # https://developer.cisco.com/meraki/api-v1/#!get-organization-switch-ports-by-switch
    AllSwitchportsBySwitch = dashboard.switch.getOrganizationSwitchPortsBySwitch(
        organization_id, total_pages='all'
    Target = []
    for switch in AllSwitchportsBySwitch:
        TargetPortIds = []
        for port in switch['ports']:
            if TargetTag in port['tags']:
                TargetPortIds.append(port['portId'])
        Target.append(
                "serial": switch['serial'],
                "name": switch['name'],
                "portId": TargetPortIds,
    for switch in Target:
        # https://developer.cisco.com/meraki/api-v1/#!get-device-switch-ports-statuses
        SwitchPorts = dashboard.switch.getDeviceSwitchPortsStatuses(
            switch['serial']
        for port in SwitchPorts:
            if port['portId'] in switch['portId']:
                print(port['usageInKb'])
if __name__ == "__main__":
    StartTime = datetime.now()
    main()
    print("\nTime to execute:",datetime.now()-StartTime)
All code is provided as is. Responsibility for Code execution is solely your own.
