Possible bug in 1.26 in GET inboundCellularFirewallRules response schema?
daniel_abbatt
There are a couple of new endpoints in 1.26 which support Appliance inbound cellular firewall rules
https://developer.cisco.com/meraki/api-v1/#!get-network-appliance-firewall-inbound-cellular-firewall...
Is the GET response correct? It's just an array of rules, which in itself is fine, but does not follow the same pattern as the following (along with many other "rules" endpoints)
The PUT for the same data
https://developer.cisco.com/meraki/api-v1/#!update-network-appliance-firewall-inbound-cellular-firew...
The GET for cellularFirewallRules
https://developer.cisco.com/meraki/api-v1/#!get-network-appliance-firewall-cellular-firewall-rules
The PUT for cellularFirewallRules
https://developer.cisco.com/meraki/api-v1/#!update-network-appliance-firewall-cellular-firewall-rule...
These other endpoints wrap the array in a "rules" property.
Can someone at Meraki please either
- confirm that the new GET endpoint is correct as documented and is an exception to this pattern, or
- confirm that the documentation is incorrect and the actual endpoint behaves like the others
1 Reply 1
Mat_Jones
I noticed this too, trying to get an example response back but it keeps being denied. I keep getting the follow error;
"errors": [
        "This endpoint only supports MX networks with IPv6 capability"
Confusingly, the example response in the docs shows an IPv4 address coming back in the destCidr field so not sure why IPv6 is a requirement.
