Meraki Umbrella Setting API Postman
Mamba123
hello community,
i have a question.
I need to activate a Cisco Umbrella Key in an organization with 200 locations.
In the dashboard you do this under Network-wide-> General and there at the bottom Cisco Umbrella account.
Can I also enter the key via API with Postman? I'm sorry but I did not find anything.
If it goes under what point in API Collection is it described? I have the current API Collection 0.11.0
Thank you.
greeting
Max
6 REPLIES 6
CptnCrnch
Looking at https://dashboard.meraki.com/api_docs/v0 there seems to be no API endpoint for this
Yes, I also looked there. Unfortunately I don't find anything there either.
Nash
This would be a great endpoint to add, and not one that I think I've heard of. "Add Umbrella to 234252 networks" is going to be a common use-case.
@DexterLaBora Hey friend, whatcha think?
On the plan for v1, coming this summer.
Same problem here, no API integration. Lots of network to apply the key/secret. Does it has to be done manually?
API - v1.8.0
Hi DexterLaBora,
do you see any chance of having an endpoint for this soon?
Thx.
