Creating Multiple Networks by using Python at the same time
Sheeraz
Just browsing
Hi All,
I have just start working on Python and Dashboard API where I am trying to achieve the result where I can run the script and it reads the serials of the devices from excel sheet and then create the network on the dashboard. Can somebody help me in this regard?
Regards,
Sheeraz
1 Reply 1
Check out this site for lots of examples:
https://developer.cisco.com/meraki/explore/
This one is close to what you are wanting.
https://developer.cisco.com/meraki/build/google-forms-with-the-dashboard-api/
Also are you aware of the bulk network creation tool?  Note that it can't do modern combined networks.
https://documentation.meraki.com/zGeneral_Administration/Templates_and_Config_Sync/Using_the_Bulk_Ne...
