Can we control Uplink Band width Usage on APs using API
Farrukh
Can we control  uplink Band width Usage on APs using API.
4 REPLIES 4
Edgar-VO
Hi There,
I think it is a combination of creating or updating an RFProfile and assigning the RF profile to the AP or SSID
https://api.meraki.com/api/v0/networks/:networkId/wireless/rfProfiles
Haven't done that yet.... Maybe i will try it someday
You could use something like:
https://dashboard.meraki.com/api_docs/v0#update-the-attributes-of-an-ssid
Take a look at these parameters:
  • perClientBandwidthLimitUp
  • perClientBandwidthLimitDown
If you are using RADIUS you can also assign bandwidth and group policy settings.
You could also dynamically assign group policies to clients.
Actually i am looking for over all bandwith limit or uplink bandwidth limit
I can't find any API settings to let you set the overall SSID bandwidth.
