Bluetooth Dashboard API Method
csullmeraki
Hey all!
I am having a bit of trouble accessing the bluetooth settings using the dashboard API. Here is the code:
def getBluetoothSettings(network_id):
     response = dashboard.bluetooth_settings.getNetworkBluetoothSettings(network_id)
      print(response)
When this runs I get "DashboardAPI has no object or attribute bluetooth_settings"
Any ideas?
2 Replies 2
sungod
Which API are you using?
https://github.com/meraki/dashboard-api-python
If you're on V0, at a guess try BluetoothSettings instead of bluetooth_settings
tbh I haven't used V0 much, I switched to using the V1 beta for everything, I've found it stable/reliable the last few point releases
I am using v0 but also got the same error:
AttributeError: 'DashboardAPI' object has no attribute 'BluetoothSettings'
