Working on a small project, new to this, but would highly appreciate the help.
Hey world, hope everyone is having a nice day.  I have just been assigned a task for a school. The goal they want to achieve is being able to monitor the students iPad's within the classroom. I done a little research and came across this, I am just wondering am I going down the right path and if not can someone point in the right one.
The tasks at hand would be,
Task 1 - to control all iPads from a desktop. So if the teacher puts google on their desktop it will come up on all iPads. Is this possible?
Task 2 - to block or restrict certain apps on the iPads.
Again any help would be highly appreciated.
5 REPLIES 5
Re: Working on a small project, new to this, but would highly appreciate the help.
Task 2. You are able to disable the app store and push the apps you want with the Meraki MDM.
Hi @kYutobi ,
Thank you for the taking your time to help, I am very thankful.
Hi @irish_dann
I came across the following Urls while looking for solutions to your requirement.
https://documentation.meraki.com/SM/Profiles_and_Settings/Configuring_Apple_School_Manager_for_Share...
https://www.airserver.com/Usage/Education
As @kYutobi Cisco Meraki SM/ MDM can assist you managing the iPad's with ease.
Regards
Ajit
ajitsnw@gmail.com
You can definitely do the second task with systems manager.  I think for the first task you would need to use some type of screen sharing solution.
1: Classroom app https://apps.apple.com/us/app/classroom/id1085319084
2: SM app as prior stated
