Shows Limited Options in Wireless Settings in the Dashboard
Noushad
Does anyone has an idea about the limited options in my dashboard?
I don't even see the options to change the ip.
Can anyone support me please?
10 Replies 10
DarrenOC
Looks like you don’t have full Administration rights.  Are there other Admins in your Org who could confirm what rights you have?
Not really. I have recently joined here. I'm the only one admin.
DarrenOC
Hi @Noushad , what Meraki products do you have deployed?  Your dashboard view is very different to mine.  I suspect you're using the Meraki Go products?
Thanks for the response Darren, I'm using MR 33. Really strange that it doesn't give me admin access.
DarrenOC
That is strange indeed.  What do you see under:
Organisation > Configure > Administrators
What access privileges are you seeing for yourself?  Do you get the same behaviour from a different browser?
Your limited view is beause your on a branded  page. Ask your provider or admin about it.
https://documentation.meraki.com/General_Administration/Organizations_and_Networks/Dashboard_Brandin...
DarrenOC
Morning @ww - I think you've hit the nail on the head with that one.  Makes perfect sense.
Noushad
Thanks! I'd check that.
Noushad
The support in this page doesn't work.
so do the phone number
For Support Kindly Call-800 34 4357 ( DG HELP ), ext-3 or Mail to - businessquickstart@sharafdg.com
Nothing works
Noushad
Any way to remove the branding MSP?
