Merkai Systems Management App Disappears
EnergyOne
After adding an iPAd via Apple Configurator 2, I wanted to put the Merkai Systems Management app on the iPad with the other apps I've set up in Merkai Dashboard. It says it installs successfully however the app doesn't appear on the homescreen of the iPad nor can I read any GPS, send an alert, etc from the Dashboard without the app.
1 Reply 1
Simo-s_h
It's Meraki Systems Manager btw.
Have you tried installing the Meraki app from AppStore?
Does the iPad show in the Dashboard that everything is up-to-date? Settings and management?
The app shows installed?
