Feature Request: Accessing voicemail from external phone/PSTN
Feature request - to provide the ability for a Meraki user to access his/her voicemail over PSTN instead of only by desk phone or email.
Accepted Solutions
Re: Feature Request: Accessing voicemail from external phone/PSTN
Hello there,
Remember that there is a third option, which is accessing your voicemail via the Phone Portal. More information about it can be found here. In any case, your idea is still welcome and you can definitely use the "Make a Wish" button on Dashboard to sent your request to us formally.
Thank you!
1 REPLY 1
Hello there,
Thank you!
