SSH-RSA Depreciation
Lurick
I recently noticed when on-boarding a Catalyst switch on 17.6 and 17.9 code that I'm getting tons of the following log messages:
ssh public-key algorithm compliance violation detected.kindly note that weaker public-key algorithm 'ssh-rsa' will be disabled by-default in the upcoming releases.please configure more stronger pk algorithms to avoid service impact.
I know I can suppress these messages in the logs but I was wondering if there is a better way or if there is a roadmap item as to when ssh-rsa will be removed on the Meraki dashboard side and replaced with something else in the future so we don't have to suppress these messages.
4 REPLIES 4
jorisjean
Same problem here with 9300 running 17.4
Used this command to remove the annoying logs from the buffer
logging discriminator MERAKI mnemonics drops SSH_COMPLIANCE_VIOLATION_PK_ALGO msg-body drops (Login Success.*meraki-user|User meraki-user has exited)
Thanks,
Yup, you could shorten it a bit if you wanted to but that's pretty much what I did as well!
jorisjean
UPDATE:
After upgrading my 9300 to 17.6.5 I had issues with DMI and netconf
Apr 26 05:42:49.816: %DMI-5-SYNC_START: Switch 1 R0/0: dmiauthd: Synchronization of the running configuration to the NETCONF running data store has started.
Apr 26 05:43:02.472: %DMI-3-SYNC_ERR: Switch 1 R0/0: dmiauthd: An attempt to synchronize the running configuration to the NETCONF running data store has failed:
Apr 26 05:43:02.472: %DMI-3-DMI_DEGRADED: Switch 1 R0/0: dmiauthd: The dmi infra is operating in degraded mode. Most synchronizations from IOS to NETCONF datastore will not be performed
CORE(config)#do show platform software yang process state
Confd Status: Started
Process Status State
nesd Running Active
syncfd Running Active (degraded)
I opened a case with meraki support and they suggested that I remove my descrimanator.
It solved the netconf error. But now my logs are filled with the Deprecation warning message again.
Any other solution ? Any idea when meraki will stop using ssh-rsa ?
Thanks,
Update: After working with TAC the proper discriminator to use seems to be
`logging discriminator DROP-ME msg-body drops meraki-user|Public-key`
