I created a new port-channel and tried to attach two interfaces to it, however I received the error message below:
Command rejected: conflicts with IPv6 Snooping (FHS)
In order to attach the interfaces to the port-channel I had to remove the following line from each interface:
no device-tracking attach-policy MERAKI_POLICY
This is just information in case anyone else comes across the issue, and while it did allow me to attach the interfaces to the port-channel, it wouldn't allow me to add the device-tracking command back into each of the interfaces after they were linked to the port-channel.
Is It a Maraki switch or catalyst switch?
Have you tried to run the command default on interfaces?
I haven't tested that, but I can try that out tomorrow on an unused port.
The switches are Catalyst 9300s.
Thanks @DevOps_RC for the workaround.
I have the same problem here with a 9300 running 17.04.
Ports that were already in a port channel before the on-boarding seems fine but i can't add new ports.
Do you have an update on this issue ?
I had he same issue with 17.9.4a on one of my 9300 switches. I defaulted the interface and than had no issues adding it to the port-channel.
you need to
- remove policy from ports
- add ports to port-channel
- add policy "device-tracking attach-policy MERAKI_POLICY" to port-channel
example:
interface TwentyFiveGigE1/0/10
switchport trunk native vlan 230
switchport mode trunk
channel-group 1 mode active
end
interface TwentyFiveGigE2/0/10
end
interface Port-channel1
end
otherwise the Meraki dashboard not will detect the ports and VLAN configuration and you can have a mismatch VLAN on port or other cosmetics errors in Meraki dashboard
I had this issue (9300 core with MS390 edge switches).
I have removed the policy, sorted the port channel and then readded the device-tracking attach-policy MERAKI_POLICY on the port channel, but i am still seeing a VLAN mismatch in the dashboard.
The port config shown in the dashboard for the 9300 out of date and shows the old settings on the interfaces in the port channel. is there a technique to make it refresh and get rid of the vlan mismatch?
I'm not aware of a way to force the refresh of config, as it should do this periodically. I'd suggest maybe removing the device from the dashboard and re-onboarding it. Not a helpful suggestion I appreciate, but that usually solves most of my issues.
