Catalyst to meraki cloud
Yeshwanth
Does existing catalyst switches also can be integrated to meraki dashboard .
If yes, Please let me know to do it.
5 REPLIES 5
Jeff-L
Yes, existing Catalyst switches can be enabled for Cloud Monitoring in Meraki Dashboard. Details regarding supported software/hardware and the process is available at https://documentation.meraki.com/Cloud_Monitoring_for_Catalyst.
AjitKumar
Hi @Yeshwanth
Also find the List of Supported Catalyst Switches in the below thread.
https://documentation.meraki.com/Cloud_Monitoring_for_Catalyst/Onboarding/Supported_Catalyst_9000_Se...
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
thomasthomsen
You cannot (yet) have them managed by the Dashboard, but you can have them monitored, by using the tool on the inventory page to setup your Cat9K switches (except 9400).
The tool (if you prepare a little bit, and follow the instructions) should do everything for you.
Quite easy actually.
@thomasthomsen thank you for this.
No Worries
