C9500-24Q with QSFP-4SFP10G quad cable in first four QSFP ports has incorrect VLAN mismatch error
Rebar
Just browsing
We have a two switch stack with QSFP quad cables in the first four ports of each switch, these equate to Te1/0/1 -16 or Te2/0/1 -16, yet the AI in the dashboard seems to think these are neighbor ports to other devices.
I think the confusion is in how the interfaces are numbered.
We have the following:
Te1/0/1 -16
Fo1/0/5 -24
and
Te2/0/1 -16
Fo2/0/5 -24
When we do a show inv raw, we see that the "Fo1/0/1 Container" has the first Te1/0/1 -4 interfaces grouped.
Can the dashboard code be fixed to better recognize this configuration?
The topology view is off as well for our stacks that are hub and spoke topology to the core 9500.
1 REPLY 1
Ryan_Miles
I would recommend you open a Support case for this issue.
