I had the issue "Device is not eligible for onboarding. Reason: Unable to connect to TLS" with a Catalyst 9300 switch using the management interface for onboarding. On this platform, the management interface is dedicated to the Mgmt-vrf VRF. Is this setup supported for onboarding?
Once I created a VLAN on the switch and connected the switch to the default VRF, then it was able to be onboarded.
Typically with Catalyst switches, we're often managing them from their MGMT port which is in the Mgmt-vrf. If Meraki can't onboard a switch using this interface, it would be appreciated if the issue could be fixed and/or mention this in the release notes. Thank you!
-Justin
