MR86 with 2 antennas MA-ANT-25
amdam_sm
Hi!
I´m about to implement an MR86 Meraki AP with two antennas MA-ANT-25 but I couldn´t find any information related with the voltage that is required of each antenna, I need this info in order to know the voltage usage in my switch.
I need your help, plis. c:
The antennas connect to the AP, they don't need any additional power input.  The AP generally would be powered by a PoE switch or injector and they generally supply 48V or so.
Thank u c:
GIdenJoe
Also important.  I hope you mean 2x MA-ANT-25 parts what actually means 4 physical antennas.
You need to connect all 4 ports on the MR86.
