MR36 160MHz bandwidth
brad_bunce
The hardware specs for the MR36 say that it can do the 160MHz bandwidth... is that available in the firmware and enabled via Support only?  It is not in the dashboard.
I see the data sheet was recently updated... 160MHz is no longer listed so thank you.
https://documentation.meraki.com/MR/MR_Overview_and_Specifications/MR36_Datasheet
Ryan_Miles
80MHz is the max width supported on the Wi-Fi 6 APs. Only the 6E APs and in the 6GHz band are 180MHz channels supported.
Ryan / Meraki SE
If you found this post helpful, please give it Kudos. If my answer solved your problem click Accept as Solution so others can benefit from it.
KarstenI
And this is a good decision. People using 160MHz should be CENSORED (sorry, that would be NSFW).
