Can the MT30 Automation Button toggle power for the MT40 Power Sensor?
YESNetwork
Is this possible? It does not appear to be conventionally possible but maybe through a webhook/automation? Otherwise this would be a great feature to suggest to the Meraki team.
1 Reply 1
Ryan_Miles
There's not a native automation for it today. You'd need to create an automation of some type that some middleware would take in and send out an API call to toggle or cycle the MT40 power.
For now I've just been using iOS shortcuts to do that.
Ryan / Meraki SE
If you found this post helpful, please give it Kudos. If my answer solved your problem click Accept as Solution so others can benefit from it.
