Source based / Policy based NAT
Frank-NL
Does anyone know if there is better policy/source based NAT configuration options coming to MX?
We would like to define the specific outgoing IP-address per subnet or Vlan. This is possible to do but only per host with 1:1 NAT. It's also possible to select WAN uplink but not a specific IP on a certain uplink for a specific Vlan/subnet.
Kind regards,
Frank
It still beta, but you can ask Meraki team support to enable it.
Can you elaborate on that? According to the support engineers its not in development:
In that case, the answer is still no, and that is not something currently in development. You can request this as a feature by using the "Give your feedback" button on the bottom right of any Dashboard page however.
Maybe they use a different terminology which I should use in my case?
Frank-NL
Thanks thats great news, I'll look into that
