A new beta cellularGateway firmware version is available. Firmware MG 3.201 was just released on 2024-05-02 and has been in this firmware category since 2024-05-02.
For MG51/51E, Applying this firmware will upgrade the firmware of the Modem. This upgrade begins automatically after the MG has finished upgrading to MG 3.201. This upgrade will require 250 MB of data and up to 20 minutes (depending on bandwidth) to complete if uninterrupted. Please contact Meraki Support if you have any additional questions or require assistance.
New feature highlights
MG51/51E Cellular Modem firmware upgrade (Verizon Band N77)
Display IPv6 info on LSP
Bug fixes
MG41 - Fixed issue that caused MG to report “SIM Not Inserted” while online via Cellular
MG21 - Fixed issue causing Modem reboots
No cellular connectivity after SIM1 Failover
Fixed issue that would cause frequent ‘boot_count” reboots
MG41 - Fixed issue that would prevent integrated modems from initializing after a reset
Enhanced support and error correction for Modem Upgrades
Radio Toggle button added to Local Status page
Shortened the Cellular uplink Connection Monitor success/retry times
MG41 - Fixed rebooting to resolve connectivity while Connection Monitoring is good
Known issues
MG21 Unable to set MTU
Periodic MG Reboot
To start contributing, simply sign in with your Cisco account. If you don't yet have a Cisco account, you can sign up.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_728c64606927e1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_728c64606927e1_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_728c64606927e1_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_728c64606927e1_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_728c6457096141","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
