Documentation correction : Meraki Wireless for Enterprise - Security
RaphaelL
Hi ,
Section :
Meraki Secure Connect
Is that part about SecurePort ? Or Secure Connect , this is confusing since they both had the same name. Can't find any documentation about Secure Connect expect that page.
https://documentation.meraki.com/Architectures_and_Best_Practices/Meraki_Wireless_for_Enterprise_Bes...
Edit ; forgot the URL to the documentation...
Ryan_Miles
It's definitely referring to a form on what's now called Secure Port.
Ryan / Meraki SE
If you found this post helpful, please give it Kudos. If my answer solved your problem click Accept as Solution so others can benefit from it.
RaphaelL
The screenshot is also very different from what I have as configuration available for SecurePort...  very curious !
versus
Yes. It’s for something a little different than secure port. Doc needs a number of corrections and I already flagged it a week or two back for updating.
Ryan / Meraki SE
