@RaphaelL is correct and I see an internal bug filed on this already. As suggested I would open a case so they can attach yours to the parent case/bug and hopefully it will add add some traction to getting this resolved.
Ryan / Meraki SE If you found this post helpful, please give it
Kudos. If my answer solved your problem click
Accept as Solution so others can benefit from it.
